Ga door naar hoofdinhoud
All-in-one PC, HD, PC/TV, 22' widescreen, Blu-ray drive, wireless LAN, 500GB HD, LT line
7 Vragen Bekijk alle
Sony Vaio VGC-LM1E Recovery reinstall
I have the above machine with its recovery disks, I recently changed its hard disk because the original one that came from the factory shook them. I gave him a 500gb 7200 rpm. I would like to reinstall windows vista home premium from the recovery disks that I have, however, I get the following misleading message:
cannot use this recovery disc for the computer confirm the model type sony vaio
Do I have to do something with cmd to find the new hard drive I put in? From the bios you recognize normally, the factory reset of the computer simply does not proceed.
Is dit een goede vraag?
2 opmerkingen:
Hello, I have the same machine and I want to take it back to factory OS spec, would it be possible to upload the disc images from the recovery disk onto the internet and maybe post a link here?
Many thanks
alex
door
I would recommend you move to Windows 7.
door
Voeg een opmerking toe
1 Antwoord
Have you tried pushing the enter key when it asks you to confirm? You could also try making a bootable Windows USB and try booting from that. (Maak een USB-opstartschijf voor Windows 10 aan). If your system was designed to run Vista, I'm not sure if you could install Windows 10 and have it work well though. Another thing you could try doing is buying Windows Vista installation disc on eBay or some similar platform. Good luck!
Was dit antwoord nuttig?
Voeg je antwoord toe
SoneiGr SoneiGGr zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 63
