Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De HP ProBook 650 G1 is een 15,6-inch zakelijke laptop die in 2013 op de markt kwam, ontworpen voor professionals die een balans zoeken tussen prestaties, duurzaamheid en prijs-kwaliteitverhouding. Het biedt een reeks configuraties om aan uiteenlopende behoeften te voldoen, van dagelijkse kantoortaken tot meer veeleisende applicaties.
Who do I fix boot device not found(3FO)
My pc was online and when I was installing Linux Ubuntu dual boot additional to windows the battery pluged out and when I opened it it gave me the error boot device not found (3FO), I checked the memory and harddisk status and It says passed
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
It sounds like you might've corrupted both OSes on your hard drive when you tried to install Ubuntu. I believe that when Ubuntu is installed in a dual-boot setup, it "scoots" Windows over a little bit on the hard drive and slaps itself down on the half that's left. My guess is that it was in the middle of this process when your battery went out, and, as a result, both bootable OSes are now unusable. Try making a bootable Windows USB (How to Create a USB boot drive for Windows 10 - iFixit Repair Guide)and see if you can boot from that. Or you could also try booting from a Linux Live USB. I'm sure you're aware of how to do this since you were installing Ubuntu, but here's the guide for that (Install Ubuntu desktop). If you boot from the Ubuntu Live USB, go into "Try Ubuntu" and see if you can get any of your data back. My guess is that all your data got corrupted with Windows, but maybe you got lucky and some of it is retrievable. I just hope you had a current backup :). Just make sure you plug your computer in before you try that again (hey, that rhymed!) Let me know how it goes!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Petros Melaku zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 35
Altijd: 739
