Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De tweede generatie Buick LaCrosse werd volledig opnieuw ontworpen en bracht de modelnaam aanzienlijk naar een hoger segment, waardoor het de grote premium vlaggenschip-sedan van Buick werd.
Replaced broken fob using same key not programming
I broke key fob but still had key.got a new fob put the old key in it but it won't program to the car.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
If you have replaced a broken key fob with a new one but the fob is not programming to your car, there could be a few reasons for this issue. Here are some troubleshooting steps you can try:
Check the battery: Ensure that the new key fob has a fresh battery installed. A weak or dead battery can prevent the fob from properly programming to the car. Replace the battery if needed.
Follow the programming instructions: Refer to the owner's manual or contact the manufacturer or dealership for the correct programming instructions for your specific car make and model. Make sure you are following the steps correctly and in the proper order.
Reset the car's programming mode: Some vehicles require you to reset the programming mode before attempting to program a new key fob. This can usually be done by cycling the ignition on and off or using a specific sequence of buttons. Consult your owner's manual for the reset procedure.
Verify compatibility: Ensure that the new key fob is compatible with your car's make, model, and year. Key fobs are often specific to certain vehicles, and using an incompatible fob may prevent successful programming.
Also try to ask for help from https://goit.global/ph/blog/it-training-... : If you have followed all the steps correctly and the key fob still won't program, it's recommended to seek assistance from a professional locksmith or contact your car manufacturer or dealership. They will have the necessary expertise and equipment to diagnose and resolve the issue. Remember that the process of programming a key fob can vary depending on the car make and model. It's essential to consult the appropriate resources for accurate instructions.
Was dit antwoord nuttig?
Voeg je antwoord toe
B.Cizzle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 39
Altijd: 956
