Ga door naar hoofdinhoud
De tweede generatie van de Kawasaki Ninja 500R, oorspronkelijk de EX500 en de GPZ500S in sommige markten, geproduceerd door Kawasaki tussen 1994 en 2009.
No start just clicking
Stopped it from blowing fuses but still clicking no start
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Does the click comes from starter? or from the relay?
I had the same problem, would hear a click but no turning whatsoever form the starter motor, after a bit of unrecalled troubleshooting I ended up on starter motor, removed it, opened it, and indeed the brushes were done for, no problem, ordered new ones for a few bucks, soldered them into place and it's starting fine ever since, even though I only used electronics solder and didn't bother welding/jbwelding the connection (still a little afraid that the solder will crack with vibrations and I'll have to open the starter again).
Since you're opening the started engine, grab a caliper and measure the commutator diameter, normally the brushes erode first, but the commutator also erodes and the diameter needs to be within specs, then don't forget to clean the brushes side and grease the gears side. Check the Haynes manual for these models it breaks down step by step of removal, disassembly and inspection of the starter motor.
If you don't want to go through the trouble of removing carbs/airbox and starter, maybe you can open the flywheel window, plug a socket with an impact wrench to the stator and spin it (to the right direction), but I'm not sure if that's a better alternative...
Was dit antwoord nuttig?
1 Opmerking:
Iam going to try that thanks
door
Voeg je antwoord toe
Fanboys of the Round Table zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 571
