Diagnosing an EC 3099 that isn't turning on
Hi everyone,
I have an A1534 EC 3099 that doesn't turn on. It was given to me by my friend, since they couldn't use it in this state.
I have repaired phones before, but nothing more than replacing the display/battery/charging port - so nothing that required micro-soldering. The repair shop quotes $200 for the repair.
I have used the iFixit guide to open it. The charging connector seems clean, so the that shouldn't cause the issue, but on the other side of the logic board, there seems to be a blown part labeled R22.
I've managed to find 10pcs of R22 on AliExpress for $6, but I only have basic tools, like a simple soldering station.
So my questions are:
- Should I tunnel vision on the blown R22? If yes, what else do I need to replace it? I've read I need a smaller soldering iron tip, a soldering flux and a microscope (I do have that, not a professional one or anything, but it works). I do not have a hot air station.
- Is there anything else I should diagnose? The multimeter says 5V 0A, so it's not turning on I guess.
If you'd suggest a completely different approach, please do let me know.
Thank you!
Edit: Adding pictures
Is dit een goede vraag?
2 opmerkingen
@dotmiracle post some pictures of your complete board and mark the location of the component. That way we can probably identify what it is and if, and how it is even connected to your issue. Voeg afbeeldingen toe aan een bestaande vraag
door oldturkey03
@oldturkey03 I have added the requested pictures. Thank you!
door dotmiracle
