Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Xiaomi Redmi Note 9S is een mid-range smartphone van Xiaomi die in maart 2020 werd uitgebracht. Het toestel heeft een 6,67" IPS LCD-scherm, een 48 MP hoofdcamera, een 5020 mAh-batterij en draait op een Qualcomm SM7125 Snapdragon 720G.
How would I replace the volume button?
So after 2 years and 8 months, the volume buttons on my Redmi Note 9S quit on me. First, the down button stopped working and then the up button. They've lost their clickiness. I know I need to replace the hardware, and I'm worried it's going to cost me a fair bit compared to what I spent on it initially. I thought of sourcing the part and DIYing it myself. The only problem is I can't seem to find a guide or a video showing what I need to do for the volume button replacement. Any help would be much appreciated.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi Bronson,
Ask and ye shall receive! As you've already found, iFixit doesn't have a guide for you, but there are a lot of phones out there and they can't do everything. Fortunately, there are other sites who share iFixit's vision, and the Spanish site Nadie Me Llama Gallina has just what you're looking for.
Manuales / Xiaomi Redmi Note 9S / Side push buttons
You can find replacement buttons on the usual sites like eBay and AliExpress. Here's an example.
New Power Volume Side Key Button Flex Cable Ribbon For Xiaomi Redmi Note 9S 9 Pro Replacement Parts
Good luck; let us know how it goes!
Was dit antwoord nuttig?
Score 2
5 opmerkingen:
Thank you so much Jerry W. This is the tutorial I was searching for. I truly appreciate the help mate. You made my day 😁
door Deel
Same problem has happened with my same model.
Instead of changing buttons, I have enabled "accessibility menu" ( it is like the function button it will appear near down on screen buttons which we touch frequently) from Settings.
door Deel
@farazali Thank you, Faraz Ali, that is an excellent workaround for those who aren't confident in their ability to do this sort of repair.
door Deel
I have redmi 9 with no sond keys up and down, it has been pulled out. The phone is stuck on rice droid logo. Is there a way, to fix, recover, reinstall rom only with power button
door Deel
Maybe one of the buttons on constantly pressed which leads to a boot loop. I would try disconnecting it and start it with no buttons
door Deel
Voeg je antwoord toe
Bronson Jayamanna zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 71
Altijd: 3,528
