Ga door naar hoofdinhoud
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
20 Vragen Bekijk alle
Horizontal screen distortions, display?
Hi Dan,
I have one of these in for repair with horizontal distortions. Would that indicate a ribbon cable problem? When i tilt the lid in a specific angle it gives me a perfect display. Thanks in advance
Update (05/14/23)
These are a bit dark..
Is dit een goede vraag?
2 opmerkingen
Can you post a picture so we can see what you see.
door
I did sent some pictures, thanks!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
While tilting the lid alters the screens reaction this is not a cable issue, it’s a bonding issue of the cable to the displays LCD panel. Sadly this is repairable issue, it will require a new display assembly to fix.
Here’s the guide Retina MacBook 2015 Display Assembly Replacement
These displays are getting hard to find, you may need to search for a used broken system to get it.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for your reply. That's a pitty.. So I better not open it up to replace the ribbon if that's useless. Thanks for your kind help!
door
Voeg je antwoord toe
Egbert Kappert zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 96
