Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
20 Vragen Bekijk alle
Battery shows charged but will not keep phone on
Trying to use a 1st gen iPhone. When I got it the battery was dead. Charged it fully. Icon reads full or on AC power when plugged in. However, when I pull the ac power, the phone will not sustain power. Oddly, if I toggle the lock/unlock button, turning the screen off and on, it seems to stay on indefinitely. But if I let it sit, even a minute or less, it will not come back on until I plug it in. When I do, the batter still shows full power or AC power. I have done a full restore and update. So it's charging. Running on AC power. Running battery power as long as I'm using it. Even took the auto lock off for 5 minutes. It stayed on. But if it sits on battery, it will not come back on.
Thoughts?
Is dit een goede vraag?
Score -1
2 opmerkingen
I'd put money down that the battery is bad. Definitely try swapping that out first and seeing if it fixes your problem.
door
I've got a question, not an answer. Did you try replacing the battery? Did it work? I have the exact same problem.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I would definitely start with replacing the battery. iPhones do weird things with bad batteries. Here is the guide, and I am sure you know it's a bear of job. The battery is available here [gekoppeld product ontbreekt of is uitgeschakeld: IF105-017] Hope this helps, good luck.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
brodave872 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 846
