Ga door naar hoofdinhoud
The larger edition of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
Unable to retrieve data
I busted the rear facing camera on my Galaxy S10+, so decided to replace it, and while I was at it, thought I'd replace the charging port that had been a problem for almost as long as I've had the phone (had to wiggle the charging cable just right to get it to charge). The repair went great, and phone functioned better than ever for one week to the day. Then, the phone shut down and entered a boot up loop. I tried a hard restart, and the phone went to a Kernel Panic screen. I tried every remedy I could find with no success. Thinking that it might be a hardware incompatibility problem with the new camera, I tore the phone back down, replaced the new camera with the old one, and reassembled. After that, the screen was blank - it would vibrate, indicating that it was connected to the charger, or trying to boot up, but no image on the screen. I took it to a phone repair, and they diagnosed a short in the charging port. They also estimated $250-450 for repair and/or data recovery. Thinking I could address the charging issue, I again disassembled, re-soldered the charging port, and reassembled. Nothing.
Any suggestions? Have I damaged the LCD assembly in some way? I would like to get the photos, videos and contacts off the phone, but have a hard time justifying $250-450. What if I got a replacement phone and put the old motherboard into the new phone to retrieve data; would that make sense?
Thanks... a newbie at repair here, taking my licks.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
check all the pins on the port, there might be a ripped trace or loose pin
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Josh zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 247
