Hi, I happened to read your post. Pretty frustrating. There's a way of course.
Boot into Single-User Mode. How? Turn on the Mac. When heard the chime, hold Command+S keys.
Mound the HD. Once Single-User Mode loads (black screen), type in:
/sbin/mount -uw /
Remove the 'Setup has been completed' file. How? Type in:
/rm /var/db/ .applesetupdone
Why such? This delete the file '.applesetupdone' in the /var/db/ director which checks on Startup to make sure the Mac has been setup. Since you have a problem somewhere around, we are resetting it creating a new Administrator Account.
Now, you reboot after the aforementioned command being typed in. How?
Simply type in: reboot and hit return.
Here what happens is your computer restarts and walks on with you as if it has been turned on for the first time so please walk through accordingly.
Once you continue Setup, make sure to select 'DO NOT TRANSFER MY DATA'. Why? Because you don't want to see the same grey screen loop again. Once you complete the simple setup as guided by your computer, come to the new user (Admin) account. And if you need, you can backup your files, music, media, act from your old user account because it has been saved in your USERS folder as "OLD USER". While setting up a new USER or ADMIN as we discussed, just make sure that you are not giving the same Old Name. Give it a new so that overwritten probability is secured.
Let me know if you're successful. My site is: acmt.newroadplaza.org Can leave me a written message from there too.
Cheers!
5 opmerkingen
Did you run Apples 'Disk Utility' to repair the permissions on the drive? If not give that a try.
door DanJ
Yes i have tried this. it found a few issues and repaired but nothing more than expected. i have also tried resetting PRAM and SMC just incase.
door Macfan1463
OK, Do you have the install DC/DVD's that came with your system or have a logo'ed OS CD/DVD to boot from? Or an external disk with a working OS on it to switch to? If using a CD/DVD or external disk works then you have something on your internal disk thats messing you up - Refresh the OS on it.
door DanJ
I don't mean to sound a bit arsey but did you not read my actual post? thanks for the help but i have already stated that i have tried these solutions.
door Macfan1463
Yep, read them ;-} Was a little confusing so need to restate things. OK, so it's fine running on the external Right? (not the re-installed OS on the internal HD).
door DanJ
