Ga door naar hoofdinhoud
Uitgebracht op 26 oktober 2018. Modellen A1984, A2105, A2105, A2106, A2108. Verkrijgbaar als GSM of CDMA / eSIM, nano-SIM of dual-SIM / 64, 128, of 256 GB / Zwart, Wit, Blauw, Geel, Koraal of Rood. (Uitgesproken "iPhone 10 R.")
468 Vragen Bekijk alle
iPhone XR Heat Shield Removal
I bought an iPhone XR refurbished from Amazon and accidentally dropped it in water. I thought it would be fine, but after pulling out and drying it as best I could it won't power on anymore. Anyway, I decided to try and repair it myself, but after following the opening instructions, I found that my version of iPhone has a heat shield that looks like it's soldered in. Is the only way to remove it by using a solder gun? Also, I've noticed that none of the online instructions show the type of metal shield that I'm seeing after detaching the screen. Is it possible that I was sold the wrong version of phone?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Although there are subtle external differences in the iPhone Xx phones, the model number is the best way to positively identify which one you have. Obviously you can't look it up, but you can find it stamped in the SIM tray opening. Here's what Apple has to say about it.
To find the model number on an iPhone 8 or later model that has a SIM tray, remove the SIM tray and look in the slot. Make sure that you're in a place with bright light overhead. The model number is on the upper side — the side with the display.
Once you've found the model number, come on back and tell us what you found and we'll go from there with trying to help you.
Update (05/02/23)
That is indeed an iPhone XR. Again, straight from Apple:
== iPhone XR ==
Year introduced: 2018
Capacity: 64, 128, 256 GB
Colors: Black, white, blue, yellow, coral, (PRODUCT)RED
Model numbers: A1984, A2105, A2106 (Japan), A2107, A2108 (China mainland)
Details: iPhone XR has a 6.1-inch1 Liquid Retina display. The back is glass, and there's an anodized aluminum band around the frame. The side button is on the right side of the device. There is a 12 MP wide-angle camera on the back. There's a Quad-LED True Tone flash on the back and a SIM tray on the right side that holds a "fourth form factor" (4FF) nano-SIM card. The IMEI is etched on the SIM tray.
Update (05/02/23)
Ah, okay with the picture it's become clear now. What's happened is that you didn't get the screen off correctly. By any chance did you fail to take out the pentalobe screws on either side of the charging port before you started removing the screen?
What's happened is that the metal shield you're looking at is supposed to have been mounted on the LCD, but somehow instead of separating the complete display assembly from the phone, you've managed to separate the shield from the LCD and leave the shield on the phone.
Really all you have to do is repeat the screen removal procedure, only this time make sure you get under the shield this time. The only thing holding that shield in are the clips on the sides, so it will come out simply by prying on it. Oh, and double-check that the pentalobe screws have been removed or it won't come out from the bottom.
With water damage the main thing you want to do is start out by cleaning everything with isopropyl alcohol. Replacing the screen and battery are frequently required as those two parts are the most susceptible to immediate failure due to liquid exposure. With the problem you had in removing the screen, I wouldn't make any bets on whether the screen will still work; at the very least you'll have to get some good adhesive to glue that shield back onto the LCD as it's supposed to be.
Once you get that shield off, you should be good; everything else will go according to the guides.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
It reads: A1984
door
@silkyjohnson78 Can you post a picture of the heat shield that's giving you grief?
Voeg afbeeldingen toe aan een bestaande vraag
door
Added image.
door
Yup, removed the two screws, heated, used the pry tool and it just popped out that way. Really confusing. Thank you for the update.
door
The amount of people who 'follow' the opening instructions and still open these phones wrong is never ending. I've added a comment to the walkthrough to change the instructions on how to correctly remove the screen.
2 opmerkingen:
True, since I've been a member here I've seen a few cases where this same scenario has happened. In my opinion it's not so much a case of inserting the pick into the wrong place on the screen, but rather that they've failed to remove the Pentalobe screws first. Obviously with those screws still in place the frame will not come up, but with enough heat and persistence, you can eventually get the frame/shield to separate from the LCD and come off, resulting in the same situation we see here.
door
@dadibrokeit all the people say they've followed the guide which tells you to remove the pentelobes first which I'm assuming they have done already.
door
Voeg je antwoord toe
silky_johnson78 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 169
