Ga door naar hoofdinhoud
The JXD S7800B is a tablet/game console that runs on an Android operating system and has built-in controls.
13 Vragen Bekijk alle
My tablet isn't charging anymore
My tablet isn't charging. The cord plugs in fine. Nothing has loosened up or broken. It just doesn't charge.
Is dit een goede vraag?
2 opmerkingen
Hi @billcornwell,
Have you checked that there's 5V DC at the cable plug of the charger?
Can you try a different, known working, compatible 5V DC charger and check if the tablet charges?
door
Yes, I've tried another 5v dc charger, another cord. My tablet's still not charging up
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @billcornwell
If the tablet isn't indicating that the charger is connected you may have to open it up and check if the DC-In jack is OK or not, i.e. ensure that there's power getting from the input of the jack to the output connected to the board.
Sometimes with these types of connectors the inner connector breaks internally and this opens the +ve leg of the power supply. The jack cannot be repaired, it has to be replaced.
If the tablet is indicating that the charger is connected but the battery is not charging it may be a faulty battery.
Here are a couple of videos that may help.
JXD 7800B disassembly
JXD 7800B battery replacement
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Bill Cornwell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 196
