What logic board component is this?
I am currently trying to resurrect a relatively expensive hair straightener. It is a Croc Infrared Titanium Ceramic 1.5-inch Flat Iron. Upon disassembly of the logic board, I did find an obvious burned out component. It does look like a resistor, but does not quite fit the pattern. It is 9.6mm in length, which would make it 1/2 watt. The part that does not look like a resistor are the ring markings. From what is left it looks like:
Black
Grey
third ring not clearly identifiable due to damage
Black
In the normal resistor world, the third ring would be the multiplier, the fourth the tolerance. Black is not an option for that. So anybody have an idea what I got here? Anybody have a flat iron apart to let me know what component I am looking at? I did try to find any schematic or diagram without success. Thanks for the help.
UPDATE
Any chance this could be a capacitor? I do know that some of them use ring markings as well.
Update Hope this is a better picture.
Is dit een goede vraag?
11 opmerkingen
http://www.csgnetwork.com/resistcolcalc.... you've probably looked at this site...
door pollytintop
Thanks pollytintop. Yes I have, but it does not match anything I come up with.
door oldturkey03
I'd just walk in to the local shop and ask them to work it out..but then I'm a girl and they take pity on me! Seriously though it's worth a shot, our local repairman often has all sorts of parts and info that is far quicker to ask him than spend all day on line. When I look at your photo it looks like there are 3colour bands side by side..white/orange/yellow (odd! maybe it's white/space/yellow?) and possibly brown to the far right? As you say black gives 0 so.. I tried searching by length of the part/ceramic but there is no match that looks like your part.
door pollytintop
Yes, it is the space that makes it look like extra rings. The part that makes me go hhhmmm is the placement of the rings. It is to symmetric on the body, unlike the resistors I have and the color black on both ends. I tried the store route, but had no luck at all. The salesperson just gave me a blank stare :-) I did contact the manufacturer (no answer yet) as well as Mouser and Digikey reps.....I guess will see. Thanks for your help....
door oldturkey03
Can we please get a closer picture of the component? When I try to blow this up it distorts. Also a picture of where it sits on the board, both side, could possibly help.
door ABCellars
6 commentaren meer tonen
