Ga door naar hoofdinhoud
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Vragen Bekijk alle
Display contains horizontal multicolor lines
Hi,
I have a 5/6 year old MacBook.
I've had the problems below for about 1 year, but they've steadily been getting worse to the point where I really need to do something about it!
Here's the problem:
The bottom half of the screen appears to be inverted (as if someone has applied reverse video!) and there is a small (1/2 an inch) horizontal line half way in the reverse video zone with multiple multicolored vertical lines inside it. Inside the small horizontal line, it's a dead zone as the display is shunted down by that amount.
If I move the screen around, or apply pressure in random places on my MacBook, sometimes I can get the reverse video to fix itself (so I'm just left with the horizontal line).
I'm certain it's not my graphics chip as when I connect an external screen, everything looks fine
Any ideas?
Does anyone think it's a cable issue or my screen itself?
Is it worth just taking a look inside to see if anything is loose?
Any help would be much appreciated!
Nick.
Is dit een goede vraag?
Score 1
4 opmerkingen
Please give us the last three figures of your serial number.
door
Hi- the last three figures of my serial number are WBV.
My Mac is A1181 if that helps also.
Cheers! Nick.
door
Attached is a picture I took of my screen if this helps also: http://i43.tinypic.com/2mrxw11.jpg
door
This has shared video RAM, so it could be a flaky RAM chip. I'd try switching RAM chips around or hook it up to an external monitor prior to purchasing anything.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I have seen this same issue a few times, sadly they have always been resolved by replacing the LCD Panel. Below is a link to the guide for replacing this panel.
MacBook Core Duo LCD Panel Replacement
It may be worth reseating your display data cable to the logic board to see if there is any improvement, since you described that the fault can be altered by applying pressure around your Mac. The lines, however, certainly steer towards a faulty LCD Panel.
Hope this helps,
Wes
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
Thanks Wes for your answer here. I had suspected this might be the problem!
I had a quick look at the DIY screen fix. I've never attempted anything like this before.... do you think replacing it is something a beginner could do or would I be better off taking it to a repair store?
Thanks once again,
Nick.
door
It really depends on your technical experience, the iFixit guide rates this as a difficult repair but take a look at the guide and see if you would feel comfortable to do this yourself.
Good Luck!
door
Voeg je antwoord toe
Nick Cartwright zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 584
