Ga door naar hoofdinhoud
Repair and support for ceiling-mounted bladed fans.
My ceiling fan is not working
When I on my fan switch,, the fan is not moving But I checked alot but there is no wire damage, no
Capacitor problem and not making humming sound
Is dit een goede vraag?
1 Opmerking:
Hi @khirasariya7759,
Did you use an Ohmmeter to check if the fan motor windings were OK and not open circuit, did you check if the switch is working electrically and not just mechanically?
You said "...I checked a lot..." but you didn't specify what you checked, so we don't know what you did and what you didn't check
door
Voeg een opmerking toe
1 Antwoord
Does the fan turn freely with the power off? Have you tried turning the fan with the power on?
Ron
Was dit antwoord nuttig?
Voeg je antwoord toe
Khirasariya Madhavdas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 143
