Mirowave hums when door is closed, fries switch when open
My microwave was tripping the breaker. I determined that the interlock switch wasn't being pressed properly. I added a small strip of duct tape to the door hook, and it started working. Then, a month or so later, it started tripping again. I traced it to the top door switch, so I replace it. The microwave would hum when the door open, then when I shut the door it trips the breaker again and fried the top door switch again. I tried removing the piece of tape and replace the newly fried switch, and it did the same thing. Any thoughts on what the issue could be? Thanks.
Update (04/15/23)
It is Kenmore Elite Model # 790.80373310. I also had the title backwards. It hummed when the door was closed and fried the switch when you opened the door.
Is dit een goede vraag?
