Ga door naar hoofdinhoud
Een van Sony's 13,3" modellen in de 13A multi-flip laptoplijn.
Black screen fix possible?
This VAIO shows nothing on the screen. It works fine (including the touch panel) with an external monitor.
There's no faint picture either, so it's not just a backlight issue.
The screen connector shows no damage or corrosion.
Is it possible to isolate the problem on the screen's side or the mainboard?
Update (04/11/23)
A new screen is not available for purchase and it would probably also be prohibitely expensive to buy one. It would be cheaper to find another used laptop with a working screen.
I disaseembled the screen as per the instructions to see if there is an obvious fault, but all connectors looked fine and there was no corrosion or burned parts. The test points on the PCB measured the correct 5V. I suppose it's possible that there's a bad connection in one of the ribbon cables.
Is dit een goede vraag?
2 opmerkingen
If it has a HDMI then connect it to you tv or a screen?
door
Yes it does.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
you should get a new screen to test if its the board or screen at fault.
i don't think it would be a board issue as its connecting to the monitor, but this would be telltale sign if it was a screen or board issue
https://www.amazon.com/KREPLACEMENT-Repl...
Sony Vaio Fit 13A SVF13NA1EL scherm vervangen
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
naujoks zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 509
