Ga door naar hoofdinhoud
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Vragen Bekijk alle
Upgrading iMac software and hardware
Hi All
I have an Imac 1.83 GHz Intel Core Duo Running Tiger OS 10.4.4. I would like to upgrade the software to Lion. I understand that to run Lion you need a Core 2 Duo Processor. Is it possible to upgrade the CPU in an IMac and if so is it worth it? Other wise I will just change the Ram chips and install 2- 1GB rams chips and then install Snow Leopard. I understand that Snow Leopard can be run on a Core Duo Processor. Any help would be great. Thanks.
Is dit een goede vraag?
Score -1
1 Opmerking
rj713 Thanks a lot that helped. I looked for it before I asked but I guess I was not looking carefully. Thanks I will probably stick to Snow leopard and not bother with Lion.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hello, This has been done--here is a link to one successful upgrade. If you search this web site you will find others. Good luck.
Upgrade The right processor, Core Duo to Core 2 Duo, 20" iMac?
Was dit antwoord nuttig?
Score 1
1 Opmerking:
door
Voeg je antwoord toe
bill zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 801
