Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een betaalbaardere, puur handheldversie van de Nintendo Switch-spelconsole, met geïntegreerde Joy-Con-controllers en een iets kleiner scherm. Uitgebracht op 20 september 2019.
How to remove joystick caps
Afbeelding
I have ordered new joysticks for my lite, but wanted to know if it was possible to remove the original joystick caps?
I have a pokemon edition lite with the non standard joystick colors and they are still in mint condition (minus drift). So was hoping to move them to the new joysticks.
Update (03/26/23)
No amount of pressure let the cap come off.
Seeing as the drift had already killed the joystick I decided to tear it down.
It appears that Nintendo has the stick and cap molded as a single unit in production, so its not possible to get the cap off to swap onto the new Guli sticks.
At best I might be able to get just the rubber cover off, but no idea if that would fit the Guli caps.
I am happy to have my sticks working again, but also sad that I am losing the unique coloring.
Is dit een goede vraag?
Score 1
1 Opmerking:
You can't easily, it is actually glued on.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
You should be able to just pull them off once you have the joysticks out, but I've never even held a switch lite, so you might want to verify that
Was dit antwoord nuttig?
Voeg je antwoord toe
Daniel Peregrym zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 67
Altijd: 2,475
