Ga door naar hoofdinhoud
Reparatie-informatie en ondersteuning voor achterloopmaaiers geproduceerd door de Toro Company.
Front wheels not straight
On the toro 30” time master are the wheels supposed to look as they are leaning outwards and not straight? We haven’t even used ours yet , unloaded it yesterday and just want to make sure the front wheels are right before using it. Thanks
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Since it is new, it is possible that the bolts holding the wheels in are loose. In the center of the wheels, there should be a screw or bolt that needs to be tightened. If there is no bolt visible, look closer, as there may be a cover to keep grass out.
It is worth noting that I don’t have this exact model lawnmower, but most are pretty similar in design, so please take this with a grain of salt.
Was dit antwoord nuttig?
1 Opmerking:
Will definitely check that, thanks
door
Voeg je antwoord toe
Amanda Chandler zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 425
