No fingerprint option after screen replacement
The finger print option no longer appears after replacing the screen with the OEM service pack from ifixit
Is dit een goede vraag?
It's just like a Pixel 6 in that it needs you to run a recalibration program for the finger print scanner function to work. Luckily they added the link right on the guide.
Was dit antwoord nuttig?
This did not work for me it said my version was newer.
my phone isnt recognised after i changed my screen, tried everything, spent so many hours trying to get it to work and ive just given up.
If you repaired the screen yourself, you may want to be sure that you removed the sensor (which is not included in the standard screen repair kit) off of the old screen to reattach to the new screen underneath the copper adhesive patch one inch from bottom of the screen(double check wire connections). If it was done by a shop and is under warranty, they can install the sensor themselves at no cost to you (usually***) as they either forgot the transfer or missed the wire connection.
Well this video might be helpful for you: https://www.youtube.com/watch?v=Z2gIqqBz...
Pixel imprint option not show after display change. Device - pixel 3xl
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 55
Altijd: 3,585
1 Opmerking
I have the same Problem, the whole option to set up a fingerprint dissapeared after Screen Replacement.
I tried the Calibraition tool, it runs normal, restart several times but the option for Fingerprint is still not there.
Any ideas?
door Sting2saw Deel
