Ga door naar hoofdinhoud
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Vragen Bekijk alle
Can you motherboard swap a mid 2014 and mid 2015 iMac motherboard?
My dad owns a mid 2015 27" 5k iMac and it is starting to show its age. I suggested he upgrade to a new M1 or M2 iMac mini. But he loves the 27" display of his current computer and since the 2015 iMac models don't support targeted display mode, I was wondering if it is possible to buy a cheap mid 2014 iMac that supports targeted display mode, swap the mother boards and save some computer from becoming e waste. Any help/ideas on where to look for info is greatly appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sorry it’s not that simple! The video interface internally is different so that won’t work.
How about adding more RAM if he is still at 8GB boost it to 16GB. If it’s a HDD system how about upgrading or adding a second SSD drive.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
I've upgraded the ram and the storage to an ssd in the past but he is still complaining about it being too slow in some cases. Thanks for the answer though.
door
@reagan1410 - Was this a Fusion Drive model? If it was you have a hidden cache SSD on the back side of the logic board which can cause the system to drag! iMac Intel 27" 5K Retina-scherm Vervanging van de blade SSD
door
Voeg je antwoord toe
Reagan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 48
