Ga door naar hoofdinhoud
De JVC KW-M650BT is een digitale media-ontvanger met een 6,2-inch helder resistief touch screen.
AV Input is glitchy
Background: I am trying to hook up a nintendo 64 for the head unit. So far I can get a picture but it will constantly float up and reset. Ive tried different rca cables to no success.
Do you know of any way to not have the picture float away and be glitchy.
Is dit een goede vraag?
3 opmerkingen
@ricardocapriles Do you have a PAL or NTSC Nintendo 64?
door
NTSC n64
-ricky
door
@ricardocapriles Have you tried using another composite device like an SNES/NES or old camcorder?
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
The issue may not be with the cables, it may be ports on either the Nintendo 64, or on your media receiver unit. You may want to check the connections to make sure they are clean and don't have any dust or corrosion on them. If there is no problem with the connections, it is probably just something wrong with the video output circuitry in the Nintendo. In that case if you do have the technical knowledge you may be able to open the device up and attempt to replace any faulty components.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Ricardo Capriles zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 27
Altijd: 394
