Ga door naar hoofdinhoud
Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
right trigger begun to squeak / help pls
my right trigger started squeaking is there is anyway to remove the squeaking without disassembling the controller ?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
I had the same problem with my controller but it turns out to squeaking is from the spring in the trigger all I did was hold the trigger down and the spring should be exposed and then just move it to the side with a needle and that should fix the problem
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
Which side of the trigger?
door
Thanks,this worked!Even though it still seems to be out of place compared to the other trigger the sqeaking is gone.
door
@no170846 on the right side of the trigger you should see the spring exposed,it should still be visible a little bit anyway,the left side is covered with plastic anyway
door
Thank you so much! I managed to do exactly what you said and worked!
I've had previously put some graphite power on the trigger and it worked for a while, but the squeaking had returned.
door
unfortunately, no
the only way it could be without disassembling is if something is stuck in it.
you should check for liquid/semisolid damage (squeaking probably means food grease, butter, ect. got in the trigger)
https://www.ifixit.com/Guide/DualSense+C...
however, is your controller under warranty?
also many people are complaining of issues with the triggers on this controller, so i would expect a recall of some sort, but i would still try to fix it in case
Score 1
3 opmerkingen:
if there are any food grease in the trigger can i clean / remove it without disassembling as well ?
also yes my controller is still under warrenty does it cover the squeaking ?
door
you could if you have a small enough item that could clean out the grease
but if that doesn't work, i would go the warranty route
door
thank you so much for this comment, all i did was hold down the trigger and blow into it and that seems to have removed whatever was stuck in it and it removed the squeaking.
door
It’s probably the spring that’s the issue. Use some WD-40…works like a charm.
2 opmerkingen:
It's probably just out of place like Juan's comment said,i would advise trying that first before using WD-40
door
I did that and my trigger stopped working altogether.. Use caution when doing that. I took it apart to try to clean the contact point of the pressure sensor but to no avail.
door
blow and hold down trigger on non-mouse click triggers, otherwise, no idea
my problem was with my left trigger i moved the spring and tried to bend it slightly with a knife like the other comment says but i used some super lube it’s a multi purpose synthetic grease and it’s dielectric and now it’s so smooth and i used a little of it for my thumb sticks and they are soooooooo smooth now
1 Opmerking:
you can try this by just taking the bumpers off or you can take the two halves apart like i did to make it easier
door
Voeg je antwoord toe
Jack bale zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 56
Afgelopen 30 dagen: 306
Altijd: 29,399
