Ga door naar hoofdinhoud
Model M5884 / 400 or 500 MHz G4 processor
20 Vragen Bekijk alle
m5884 dc internal broken -- how to change it
hallo... i've to change the dc connector...+ pole broken
is possible to have a guide... it is different from newer model...
i've the ac connector covered by a floor of circuit....
It's my first mac (bought in 2000) ... i would to my daughter the opportunity to play a little bit with him ...
I'm writing from switzerland and now i have my second mac... a MacBook Pro model 2009 .....
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Ifixit doesn't have the manual for this repair, but if you look here: PowerBook G4 Titanium Mercury you'll see various other rapairs that will lead you in the right direction. This repair PowerBook G4 Titanium Mercury Logic Board Replacement will most likely suit your needs.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
thank you from Switzerland ....
i'll check ....
door
No Problem. Good Luck.
door
Voeg je antwoord toe
fausto zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,808
