Ga door naar hoofdinhoud
Reparatie en ondersteuning voor de controllers die bij de PS3 werden geleverd. De six-axis controller met lithiumbatterij (CECHZC2), uitgebracht in november 2007 (alleen Japan) en 2008 (andere landen), is eenvoudig te repareren.
Why is 4 red lights blinking?
I recently took apart my DS3 and put it back together, ever since then I have received 4 flashing red lights everytime i plug it in. It does not give off any lights when unplugged
Edit: I have used the reset button and switched batteries.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Sounds like the board isn't connected to the battery properly and isn't charging. Open it up and check all the connections.
Was dit antwoord nuttig?
9 opmerkingen:
Hey and thanks for answering! Shouldn't the controller work with unplugged battery whilst connected with usb?
door
@thimstr I don't think so. Usb is purely for charging and not actual power.
door
@strongbow Well, I switched with a brand new battery yesterday and I got the exact same results, sorry for not providing this info firsthand.
door
@thimstr obviously the battery is connected. Have you tested voltage to the battery connector with a multimeter with the cable connected? Check the voltage on the new battery too.
door
@strongbow Thanks for the suggestion, I would have to bring home a multimeter from work, is there anything else I could check in the meanwhile?
door
4 commentaren meer tonen
Voeg je antwoord toe
Thim Strömberg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 41
Altijd: 1,899
