Ga door naar hoofdinhoud
Handleidingen voor reparatie en ondersteuning van alle soorten batterijen.
74 Vragen Bekijk alle
Weakening of battery capacity for Watt.
Hello, I own a MacBook Pro Retina Mid 2012.
The design capacity of my device's battery is around 50%. When I run heavy programs on my device, it either turns itself off or stops displaying the screen. does the current of the battery decrease due to the drastic reduction of the design capacity?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@shzg yes, the greater the demand from your system the the greater the output demand on the battery. A depleted battery can then no longer supply that demand and will either shut off, or your system will "invoke" power saving measures. Replacing your battery should resolve this.
Of course you can verify this by running programs like coconutBattery and evaluating the results it shows.
Since you did not tell us which exact model MBP you are referring to, go here MacBook Pro Repair and start selecting the proper system. All of them will have a battery changing guide and a link to replacement batteries.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
SH ZG zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 22
