How To Fix Dark Screen Laptop?
How To Fix HP Black Screen - Computer Starts But No Display - Screen Not Working
Is dit een goede vraag?
Hi,
Connect an external monitor to the laptop's DP or vga port and check if there's a display on it.
Toggle the F4 key to switch between the laptop screen on only, the external monitor on only or both on together.
If there is a display on the external monitor, try shining a flashlight at an angle close to the laptop screen and check if you can see any images.
They will be very faint if they are there to be seen so trying this in a darkened room may help.
If you can see images then there's a backlight problem with the screen.
This could be due to a faulty backlight power circuit, faulty or loose video cable or a faulty display.
Was dit antwoord nuttig?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 567
1 Opmerking
hp 840g3 screen backlight problem
door Biniyam Daniel
