Ga door naar hoofdinhoud
De Bajaj Discover is een motorfietsmerk van Bajaj Auto. Momenteel zijn er vier varianten van de Discover: Discover 100 DTS-Si, Discover 125 DTS-i, Discover 125ST en Discover 150 DTS-i.
It can't start
My motor bike is not starting
Is dit een goede vraag?
Score 18
13 opmerkingen
Geoffrey Ouko what exact model is your motor bike? What have you checked? Do you have fuel? Do you have spark? Did anything happen to it or did this just start all of a sudden?
door
My motor cycle not start
door
Bettry charging
Palag problem
Indicetar chlu
door
ุงู„ุจูˆุฌูŠุฉ ู„ุง ุชุนุทูŠ ูƒู‡ุฑุจุงุก ู‚ูˆูŠ
Translation Arabic - English
The spark plug does not give off strong electricity
door
@fgr31679 What make and model bike? What engine size? What year? What have you checked?
Translation
@fgr31679 ู…ุง ู†ูˆุน ุงู„ุฏุฑุงุฌุฉ ูˆู…ูˆุฏูŠู„ู‡ุงุŸ ู…ุง ุญุฌู… ุงู„ู…ุญุฑูƒุŸ ู…ุง ุงู„ุนุงู…ุŸ ู…ุงุฐุง ูุญุตุชุŸ
door
8 commentaren meer tonen
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
If your Bajaj Discover motorcycle is not starting, here are a few things you can check:
  1. Check the battery: Make sure the battery is fully charged and that all connections are clean and tight. If the battery is old or weak, it may need to be replaced.
  2. Check the fuel: Make sure there is enough fuel in the tank and that the fuel valve is turned on. If the fuel is old or contaminated, it may need to be drained and replaced.
  3. Check the spark plug: Make sure the spark plug is clean and properly gapped. If it is fouled or damaged, it may need to be replaced.
  4. Check the air filter: Make sure the air filter is clean and not clogged. A dirty air filter can restrict airflow to the engine and cause starting problems.
  5. Check the carburetor: Make sure the carburetor is clean and functioning properly. If it is dirty or clogged, it may need to be cleaned or rebuilt.
  6. Check the ignition system: Make sure the ignition system is working properly. This includes checking the ignition coil, CDI unit, and other components.
If you are not comfortable performing these checks yourself, it may be best to take your motorcycle to a professional mechanic for diagnosis and repair.
Was dit antwoord nuttig?
Score 7
Try kick start maybe your battery is worn out
Score 3
Find your spark plug location. It's may be right and left side of the engine's nearby top side. Their have an adaptor to connect spark plug and that wire. Remove adaptor and directly keep the wire near by engine and kick the vehicle to start. It may cause to electrical shock. So do it carefully. And check any spark is present or not....
Start with the basics ๐Ÿ‘
  • Check battery (most common, does it crank?)
  • Fuel on + not empty
  • Kill switch off
  • Listen: no crank = battery/starter, cranks but no start = fuel/spark issue
If itโ€™s been sitting, fuel or plugs are usually the culprit.
Voeg je antwoord toe
Geoffrey Ouko zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 225
Altijd: 8,155
