Ga door naar hoofdinhoud
MP3 player released in 2011, to replace the Clip+, available in 4 GB and 8 GB.
3 Vragen Bekijk alle
Water damage mp3 still turns on says battery is lower
My mp3 had music on it got wet turns on says firmware upgrade
Is dit een goede vraag?
2 opmerkingen:
Could you clarify on what exactly happened? From what I see, your MP3 player got water damage and now says firmware update?
door
ghostrider61198 how did you deal with this "got wet "? What did you do?
door
Voeg een opmerking toe
1 Antwoord
If your mp3 player got wet and is now displaying a message saying "firmware upgrade", it is possible that the device is malfunctioning due to water damage.
Here are a few steps you can try to potentially fix the issue:
  1. Remove the battery and let the device dry completely for at least 24-48 hours.
  2. Once dry, re-insert the battery and turn on the device. If it still displays the "firmware upgrade" message, try connecting the device to a computer to see if it can be recognized and firmware can be reinstalled.
  3. If the above steps do not work, it may be necessary to take the device to a professional repair shop or contact the manufacturer for further assistance.
It's important to note that water damage can be difficult to repair and may not be covered under warranty, so it's best to avoid exposing your electronic devices to water whenever possible.
Was dit antwoord nuttig?
Voeg je antwoord toe
ghostrider61198 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 54
