Ga door naar hoofdinhoud
Minolta SRT 200 Film Advance Lever Stuck
I picked up a Minolta SRT 200 from an antique store for next to nothing, seems to be in really good condition (very clean, things seem to work and move properly without a battery.)
But I can't move the film advancement lever beyond the 20-degree free rotation amount. With the back off the lever doesnt move any of the hardware inside.
Any ideas?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Ok, I found the answer. I removed the bottom after reading an article about an SRT201 that had a similar issue, also with the rewind button stuck in the depressed position. For whatever reason even though my keywords were identical, Google didn't think it was accurate until I searched specifically for stuck rewind buttons. I removed the bottom plate and found that the rewind lever went all the way down, and it was caught on a small ratchet pin that prevented it from opening. I pulled back the pin and actuated the rewind lever, and everything seemed to right itself, and now it works like a charm!
Was dit antwoord nuttig?
1 Opmerking:
My SRT 100X has a similar issue. When shooting, I heard an unusual noise and the advance lever was stuck. The rewind button remains depressed. I tried this same solution after removing the bottom plate but I didn't see anything strange. Anyway I'm not able to find that pin... Any help?
door
Het nuttigste antwoord
Hi @counttoinfinity
Here's the SRT-101 service manual and the SRT-303, -102 & -Super service manual that may help.
I realize that it is not they're same model as yours but perhaps the film winding mechanism operates the same way, since your model number lies between them.
Update (02/20/2023)
Hi @danj
Strange as I have no problems accessing the documents.
Here they are anyway.
Cheers
Minolta SR T 303 102 Super Repair SRT 101ServiceManual
Score 2
2 opmerkingen:
@jayeff - All the SRTs have the same film advance and shuttle design so the manuals you’ve posted are just the ticket! These appear to be behind a paywall or limited to country as I can’t get to them.
door
@counttoinfinity - Here’s another source in case you can’t access Jays as it appears they either behind a pay wall or limited to country IP address as I can’t see them Minolta SRT 101 service manual
door
Voeg je antwoord toe
Levi Giesbrecht zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 54
Altijd: 3,645
