Ga door naar hoofdinhoud
The Dyson V6 Absolute is a cordless, bagless cleaner released in September 2014, with HEPA filtration that captures allergens. Used for all floor types and weighs 5 pounds. Identified by model number SV09.
19 Vragen Bekijk alle
Why after charging and after using Max function it stops?
Dyson V6 (SV05).
I charge the Dyson. If I start it using the max button it stops in less than a minute. Then I plug it and press the button for 20secs as advised in this group and with the MAX function it stops working fast but if I turn the MAX off it works for a while? Do I need to change the battery? They are quite expensive. Thanks for your help
Carla
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It sounds like a weak battery. The Max function is powerful so it pulls more amps, which reduces the voltage the battery sends to the motor. Not enough voltage stops the motor. Probably the regular ( non Max) stay above the minimum voltage so it stays running.
This battery repair can help you.
Dyson v6 Absolute Battery Pack Replacement
Was dit antwoord nuttig?
1 Opmerking:
Thanks a lot for your answer. The instructions are great. The problem is batteries are so expensive. But at least I know why it is happening. Regards. Carla
door
Voeg je antwoord toe
Carla zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 106
