Ga door naar hoofdinhoud
Dyson v6 Absolute Battery Pack Replacement
Wat je nodig hebt
    1. Dyson v6 Absolute Battery Pack Replacement, Bin: stap 1, afbeelding 1 van 1
      • Unplug the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Dyson v6 Absolute Battery Pack Replacement: stap 2, afbeelding 1 van 1
      • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
      • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
      Vraag FixBot
      Voeg opmerking toe
    3. Dyson v6 Absolute Battery Pack Replacement: stap 3, afbeelding 1 van 1
      • Push the red lever down a second time to release the debris bin.
      Vraag FixBot
      Voeg opmerking toe
    4. Dyson v6 Absolute Battery Pack Replacement: stap 4, afbeelding 1 van 1
      • Pull bin away from the cyclone.
      Vraag FixBot
      Voeg opmerking toe
    1. Dyson v6 Absolute Battery Pack Replacement, Battery Pack: stap 5, afbeelding 1 van 1
      • Locate the screw on the battery pack.
      • Use a Phillips #2 screwdriver to unscrew the battery pack.
      Vraag FixBot
      Voeg opmerking toe
    2. Dyson v6 Absolute Battery Pack Replacement: stap 6, afbeelding 1 van 1
      • Locate the screw on the device handle.
      • Use a Phillips #2 screwdriver to remove the screw and release the battery pack.
      Vraag FixBot
      Voeg opmerking toe
    3. Dyson v6 Absolute Battery Pack Replacement: stap 7, afbeelding 1 van 2 Dyson v6 Absolute Battery Pack Replacement: stap 7, afbeelding 2 van 2
      • Pull the battery pack down and away from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
143 andere personen hebben deze handleiding voltooid.
Tabitha Espina Velasco
3.702 Reputatie
5 handleidingen geschreven
30Gids Commentaar
very good article 10 out of 10
karl thiele - Antwoord Deel
Nice article. Not too long or too short. Perfect pictures, too.
timlevin - Antwoord Deel
Great pictures, very straight forward, and I really appreciate you guys taking the time to put this together. I managed to “kill” my Dyson by getting a little over-zealous with the cleaning. I’m going to take it apart, let it dry completely, and hope that a new battery is the only issue. Anyway, your presentation has given me the courage to go forward - may not work, but…..
Meg Olhasque - Antwoord Deel
Hi, I bought my Dyson v6 for Christmas 2016. My battery only last few seconds at dis stage. It seems a short time for battery needing replacing. Is this normal .
Ellymck - Antwoord Deel
I had the same problem with my dyson v6 slim. The battery didn't last long on mine either! I was very disappointed especially when you pay $500 for one of these.
Beverley Mingo - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 138
Afgelopen 30 dagen: 571
Altijd: 309,901
