Touch screen doesn't work?
My Microsoft Surface Pro 4 touchscreen doesn’t work.
Thank you in advance for any assistance in this issue.
Jack
Is dit een goede vraag?
Jack
you need a new digitizer
also you need to open your Surface Pro 4 and look at the connectors (and upload photos if your confused and need help) BEFORE you buy anything so you can see what model you have
SAMSUNG display is below
Surface Pro 4 (1724 v1.0) Screen
LG display is below
https://www.mobilesentrix.com/lcd-assemb...
heres your guide to replace:
Microsoft Surface Pro 4 Vervanging van het scherm
also, just a side note, you can use the guide to open your Surface to see what connectors it has
happy repairing! ^_^
Was dit antwoord nuttig?
Jack, has anything happened with your tablet lately, such as any kind of drops or water damage? Have you done any kind of software updates recently? Just looking for any changes that might correspond roughly to when the issue started.
Does the Device Manager show the touch screen driver as installed and working?
While yes, it's entirely possible your digitizer has failed and needs to be replaced, it's equally likely that it could be a software problem. You'll want to exhaust the software possibilities first before you spring for a new screen.
Same issue of touch screen not working after replacing battery. Screen peeled off with issue. The pen still is working on most of the screen. There is a approx 2" wide area from top to bottom that will not react to the pen. That area is on rt side about 2" in from edge and extends toward center of screen.
@davem52722 sorry, but you might need to ask a new question, as this isn't the same as the oringal question.. i recommend making a new post for your issue
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 20
Altijd: 299
