MBP Battery stopped charging
(Added Coconut screen shot)
Suddenly my battery is not taking a charge. In "System Info: Battery Info" it shows "battery installed: NO" and the battery status is not showing in the menu bar. MBP works normally with AC power, but shuts down when disconnected. I've rebooted and also reset the SMC - no change. Coconut is not even sensing a battery. I replaced the battery with an IFIXIT battery last May so the cycle count cannot be anywhere near 1000. TIA (MBP 15" Retina Late 2013)
Is dit een goede vraag?
Bingo! This is a bad micro-controller chip within the battery. You’ll need to replace it.
Contact the iFixit store to get a replacement battery under warranty. Sadly quite a few batts from a few sources have encountered this issue as the chip is a single source and had a bad run.
door Dan
