Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
20 Vragen Bekijk alle
on my screen appear www.apple.com\support\iPod
after that turn on the screen and says very low battery and never connect
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Dj Cpheus Most of the time, the "www.apple.com/support/iPod" error message will come up when the iPod has trouble with the hard drive. You can try and place your iPod in either diagnostic mode and run the test to see what it shows. You can also try to place it in disk mode and see if you can reformat or even access the drive. The low battery could be just that, a low battery that has been discharged below the threshold at which the iPod can charge it. I believe that to be 2.7 volts. My suggestion is to check your HDD first, and replace the battery. Worst case scenario, your logic board does not recognize the drive or the battery. Check on here to see how to put it in disk mode. This should work for getting it into Diagnostic Mode
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
thank you for the answer but the ipod do not allow me to can place nothing, just appear the www.apple.com\support\ipod appear the apple logo and very low battery, and that make an again and again and again
door
Dj Cpheus Try a new battery and after that see if you can access it. There are usb adapters for your HDD that you could use to evaluate the HDD. This is a common error with a failed HDD
door
Voeg je antwoord toe
Dj Cpheus zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 516
