Ga door naar hoofdinhoud
The Samsung SCH-A670 features include 2 MB memory and a 0.3 megapixel camera.
Remove information on the phone
I would like to recycle the phone,but how do I make sure info is no longer there. I don’t have a charger so I can’t see what’s on it. Will removing the battery be sufficient ?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
cbreu419, You will need to find a way to power the phone up, in order to reset it to factory and thus deleting the information that is stored in the phone. Removing the battery will no delete the information that might be on the phone.
There are many places online that sells chargers for obsolete phones.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
You can also just drill through the NAND if you just plan on recycling it. That would probably be the easiest option if you don’t have the charger.
door
@thequacker Very true! That will definitely remove the data
door
Thank you so much . So helpful.
door
Voeg je antwoord toe
cbreu419 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 7
Altijd: 105
