Ga door naar hoofdinhoud
Samsung's flagship phone-with-stylus and the successor to the Note8, released August 2018. Features a 6.4" display and up to 512 GB of onboard storage.
104 Vragen Bekijk alle
My Note9 says no network conct, yet connected and not thru wifi
Can't call or text , says no network connection but I can do anything online and not using wifi, my icons on top rt show data connect with arrows but signal bars have x thru them wifi is not turned on i have talked with network tech and gone thru trouble shooting too many times got new sim and problem happened again, I am having to use a wifi calling app so I can make phone calls outside of Mesgr.
Any help would be greatly appreciated thank you
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Does it work if you try your sim card in another phone? Could the phone be network locked? Have you tried it with another SIM card?
Was dit antwoord nuttig?
2 opmerkingen:
Woah this is the second sim card it did something similar to this but I had no connectivity what so ever the first time, wait now that I think about it all this started when I got a text to get a new sim to get on 5g and when I got the new sim I first could not make calls or text tech fixed that but I could not send pic msgs got a new sim and it worked ok still could not send pic msgs then all of a sudden I can't call or text so idk what the problem is, we, me and tech support, came to conclusion that it was a ack that sent the message about 5g sim but idk why this problem happened again after new sim
door
I have not tried it in another device bc if the sim is bad I don't want to mess up anyone else things still not sure what the problem.
door
Voeg je antwoord toe
Nancy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 7
Altijd: 40
