Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Derde generatie Surface Pro-tablet, uitgebracht op 20 juni 2014.
Touch screen not working.
The touch screen isn't working. I purchased a Surface Pro with a bad battery and broken screen. Touch screen was working initially before screen replacement. I've tried two different screens so it doesn't seem to be a hardware issue. All of the drivers appear to be installed properly. I ran the hardware check and everything passed except the touch screen. Is there something I could've broken when replacing the screen and battery?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
There could be missing components from the tablet's board, are you able to look closely around the display connectors to look for any missing parts?
Was dit antwoord nuttig?
1 Opmerking:
I don't see any missing parts. I connected everything that I disconnected when removing the original screen. Both ribbon cables are connected properly to the panel and the board.
door Deel
Voeg je antwoord toe
Zac zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 316
