Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
lower syringe clamp replacement
the lower clamp on my baxter infuseOR is cracked. I have the replacement part but after removing the screw it still won't release. It swivels around on something i can't see. How do I proceed without damaging the pump? How do you remove the lower syringe clamp from the infusoe body?
Is dit een goede vraag?
Score 1
2 opmerkingen
@bludo2 do you have a model number for the Baxter pump?
door Deel
model # 2L3100
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Dr Linda M Ribarich-Boehm DMD is this going to help you out Baxter InfusOR Infusion Pump Service Manual
Update (02/07/2023)
@bludo2 so I spoke with the experts today and they are not sure what you refer to as the lower clamp. We made the assumption it is the syringe holder
Afbeelding
Since you did not provide any images, let us know if this is wrong too. I've now attached the complete disassembly manual for this pump. The odd and even pages are separate.
Baxter Diassembly
Was dit antwoord nuttig?
Score 2
5 opmerkingen:
the manual DOES NOT TELL YOU ANYTHING ABOUT REMOVAL AND REPLACEMENT OF A BROKEN CLAMP. Anyone can find the manual. No one can answer the initial question
door Deel
@bludo2 can you post some images of where you are stuck? You are right about finding the manual but usually it is just to assist with follow up's etc. The manual gives everyone the opportunity to "see" the same thing. Sorry it did not meet your expectation and we are working on it. Fixing things online is not like fixing it in real. We do not see what you see, so you are our eyes and ears.
door Deel
manual no good; period!
door Deel
@bludo2 got it. Let's get some pictures so I can ask my BioMed guys. See if they can come up with something.
door Deel
Voeg je antwoord toe
Dr Linda M Ribarich-Boehm DMD zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 553
