50% of mobile is not worging
My phone is not working 50 it's blank 50% is working
Is dit een goede vraag?
@rishi22 I assume you are talking about the display. Most likely a screen issue. I would get ready to replace it. While you are working on it, make sure that all the ribbon cables are properly connected and that there is no corrosion etc. in any of the connectors. Use something like this video to work on your phone and to replace the LCD. Replacement displays can be found at plenty of places with an online search.
Was dit antwoord nuttig?
@rishi22, I dug up a guide for you; apparently the R9m is also known as the R9 Plus, which is what this guide is for.
फोन लॉक हो गया है और फोन कीफोटो अच्छी
Phone is lock
Phone Batery is slow चार्ज
फोन लॉक हो गया हैजल्दी
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 18
Altijd: 589
3 opmerkingen
The cellphone won't turn on, it won't charge and the power button is broken.
door Nanz Stecu Deel
The phone would normally power on when it's plugged into power, so I suggest you start with replacing the charging port. After that you'll want to replace the power button. If you want specific help on how to do those things, I suggest starting your own question and include information about exactly what phone model you have.
door Jerry Wheeler Deel
Mobile signal problem
door Zaheer Baber Deel
