Ga door naar hoofdinhoud
This phone was announced in September 2019 and released in October 2019. It was shipped with Android 9.0 and ColorOS 6.1. It was available in the colors, Mirror Black and Dazzling White.
5 Vragen Bekijk alle
لماذا هاتفي يقوم بالخروج من البرامج بدون سبب quit programs for no reas
لماذا يقوم هاتفي بالخروج من البرامج بدون سبب
Translation
Why does my phone quit programs for no reason
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi,
Things to try and see if they resolve the problem:
  • Wipe the cache partition and check if that resolves the problem. Scroll down to Wipe cache through Recovery mode
  • Try starting the phone in safe mode and check if it works OK. If it does then a downloaded app is the cause of the problem. You will need to uninstall each downloaded app one by one and then test the phone in normal mode between each uninstall to see if the phone works OK or not. When it does work OK then the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed on the phone and it wasn't pre-instaled on the phone when you first got it.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Hagar Ebrahim zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 25
Altijd: 140
