Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Vragen Bekijk alle
The little black "DO NOT REMOVE" sticker
Does the little black "DO NOT REMOVE" sticker in the bottom right of the iPhone 3G serve any other purpose?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Nope, just a warranty sticker.
Was dit antwoord nuttig?
Score 3
Besides telling you not to remove it? No, as Chris Green says, once you remove it, your warranty is invalidated.
Score 1
1 Opmerking:
it hasn't been under warranty for 4 months now, so thats ok.
door
It's on top of the antenna wire. if you mess with it you can damage your iphone's signal or worse reflects no service.
Score -1
2 opmerkingen:
Where did you find that information? So by removing the sticker I decrease the signal ;-)?
door
no.. it's on top of a screw that holds the motherboard in contact with the battery connection. I think your antenna problem is damage elsewhere on that little wing of the motherboard.. it is easy to try to force the motherboard out and the gold prong to the antenna is damaged..
door
Voeg je antwoord toe
Jesus Terrones zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 14
Altijd: 13,459
