Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen voor de Pro-versie van de tweede generatie DJI Mavic-drones, uitgebracht in augustus 2018.
How do I fix camera shake?
The plane collided with a pilot's turn into a pole, and after that, I find a stutter in the camera from time to time, so I hope to find a way to solve this problem since the camera works
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi
This one is going to be hard
Most cameras have something called OIS(Optical Image Stabilisation) which is a physical mechanism that helps counter shaking in the camera it self ,the only way of fixing a issue with OIS is to replace the camera itself as it if very fragile and precise
However if possible I would try resetting the device as it could a software issue as some cameras have something called EIS(Electronic Image Stabilisation)
This stabilises the footage through software which could also be your issue
Hopefully this helps
Any questions please ask
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Amr Ahmed zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 23
Altijd: 505
