Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
LG 4K UHD, HDR 10, 49 inch model uit 2017
Backlight LEDS not being powered
I have a LG 49UH603V and the screen turned blue. Upon inspection the leds were almost all blue so I ordered a backlight kit to replace them.
I first removed one strip (bottom row, closest to power on button) and replaced it by a new one to check if it was working. It wasn't working but the rest of the old blue leds were turning on. Then I tried to replace the top row to see what was happening but then nothing was turning on.
So I put all the old blue strips back on and still, nothing was lighting up.
All leds (old and new) are working, I tested them.
Then I tried to measure the voltage on the power supply, the led connector on the board gave me (I think) a good reading but the little connectors going into the strips, I couldn't get a normal reading on them.
At this point I think it's useful to inform you that I have no prior knowledge about those things, just a decent sense of logic and access to YouTube. I'm guessing there is an issue with the power supply board but I really have no clue of what the next steps to source the issue should be, would appreciate any help provided :)
Afbeelding
Afbeelding
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
We had a LG TV that had the same issue twice. Both times it was the back-light power board that had failed. After the second time we replaced it with a TV from another manufacturer.
Was dit antwoord nuttig?
1 Opmerking:
Ha thats reassuring 😂
door Deel
I ordered new led strips and they also didn't work. Little figuring out and realize polarities are opposite from original tv pins. I haven't fully fixed it yet as something wrong with the ground, it works only when I ground it with my fingers to the tv case
Voeg je antwoord toe
Pamela Kant zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 33
Altijd: 1,418
