Ga door naar hoofdinhoud
The Acer Chromebook R11 CB5-132T-C1LK is a laptop/tablet hybrid released in October 2015.
Lost charge but plugged in?
I have orange battery on screen then goes dark.1% Battery indicator light blinking orange. Charger plugged in. Not charging. I unplugged and plugged back in. Not charging. I'm not techy. Is it time to get a new laptop?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi,
It may be that you just need a new battery.
If possible run a battery health check and compare the Design Capacity versus the Last Full Charge. Also check the cycle count, as mentioned in the link once it is >400 it may not last long.
If it is determined that the battery needs replacing, here's the ifixit Acer Chromebook R11 Battery Replacement guide. Search online for AC15A3J to find suppliers of the battery that suit you. The battery model number is printed on the battery if you wish to verify that the model number of your battery is the same as in the guide.
Was dit antwoord nuttig?
Score 1
Find a good repair shop. Acer are notorious for blowing mosfets. It needs the board tested to find the damaged part.
Score 1
Voeg je antwoord toe
zone3251d zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 137
