Do you need the exact same value capacitors when swapping an old one.
I'm looking to change of the capacitors on my fan but I could only find one's that are almost similar in rating. Is it okay to use the capacitors from this seller:
https://shopee.com.my/Kipas-Capacitor-OR...
Here's the PCB of my fan:
https://i.imgur.com/VOA3cWQ.jpg
As you can see some of the caps provided by the seller has similar voltage but different uF and vice versa. Should I keep looking for capacitors with the exact rating or is it okay to have some slight difference in rating?
Is dit een goede vraag?
2 opmerkingen
I have a 3.5uf capacitor 300vac and need to slow the fan. Will a 3uf capacitor 450vac work?
door A.L.F. Kuba
capacitors on motors are used to START the motor. It has nothing to do with the run speed.
door bill
