Ga door naar hoofdinhoud
Een digitale camera gefabriceerd door Canon Inc., uitgebracht in september 2010.
Camera won't turn on
My Canon (power shot sx20 )camera was stored (inside a walk-in closet with controlled temperatures) for a few, maybe 5 years, untouched. I went to use it and it won't turn on. So I replaced the 4 AA batteries and the small lithium battery inside the battery holding area. Still nothing. Does anyone have any ideas on what it could be?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @chalke,
Were the original batteries OK inasmuch that they hadn't leaked?
If they had check that the battery connection terminals in the camera are clean and bright and not affected by any corrosion.
You could try cleaning them anyway using a Q-Tip lightly moistened (not dripping) with vinegar or better still if you have some 99%+ Isopropyl Alcohol.
It could be after all this time that there's a layer of verdigris on the contact surfaces preventing a good electrical connection.
Also double check that you inserted all the batteries the correct way ;-)
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Joan Hamer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 301
