Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Model A1989, EMC 3358. Een update van het bestaande ontwerp, met bijgewerkte processoropties en een wijziging in de toetsenbordmaterialen. Beschikbaar in Zilver en Spacegrijs. Uitgebracht in mei 2019.
My touchbar is flashing
How do you stop a touchbar from flashing?
Is dit een goede vraag?
Score 10
7 opmerkingen
Can you Upload a Video?
door Deel
i think that you may need a replacement, but we need some photos to confirm that you need a replacement or not
door Deel
@djz18 - What Year/Model Number?
door Deel
@beanman56 It's a 2019 13" MacBook Pro 1.4 GHz Quad-Core Intel Core i5 Retina display with 16g memory and 1T hard drive
door Deel
i just updated mine and it stopped.
door Deel
2 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Just spoke with Apple support again and she mentioned a step no other support advisor mentioned...reset the NV RAM. To do this, I held the Option, Command, P and R keys while starting the computer. I held the keys for 20 seconds and the computer did another restart, after which I released the keys. This has stopped the flashing for now. If the flashing restarts again, I'll add to this post. Thanks for your input, if you had responded to this post.
Was dit antwoord nuttig?
Score 7
3 opmerkingen:
After using the computer for a couple of hours, the problem with the touch bar is back.
door Deel
Now what? It also worked for a very short time
door Deel
Apple might not endorse this but a strip of gaff tape over the whole thing solves the annoying flashing. Blacked out and gone. Battery life will probably still exceed woeful but, hey! it is a Mac!
door Deel
In my experience this is a sign that the Touch Bar's display is failing and needs to be replaced. It's not an unusual issue, but it is a bit of a gnarly repair due to the sheer amount of adhesive involved.
This is the process for a 2020 model, which will be quite similar as far as getting the touchbar itself out. Just for point of reference.
Score 6
2 opmerkingen:
Thanks Alisha. This is very helpful. I don’t think I want to take this type of extensive repair on myself. Do you know a good place to send it for this type of repair, other than apple?
door Deel
@djz18 That's a good question. And I don't blame you for not wanting to undertake it yourself. I would ask friends or family if they have any local recommendations. I don't have any specific suggestions, aside from not Apple since they will not do this repair independent of a full top case replacement, which is quite pricey.
door Deel
Voeg je antwoord toe
David zeve zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 140
Altijd: 22,577
