Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen, demontage- en probleemoplossingsinformatie voor Logitech's draadloze, ergonomische Ergo-muis. Te herkennen aan het modelnummer M-R0065 of onderdeelnummer 910-005177.
Trouble with left click button
Hello, I am having trouble with left click button, especially when dragging windows. I think similar problem exists in other trackball mice as well. Hoping to find a DIY solution.
Regards,
Sachin
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Filteren op:
Hello Sachin,
I didn't myself have had any trouble with the Ergo's switches, but I did with other mice. The solution to your problem would suggest a problem with the switches. Since I don't have specific experience with the Ergo switches, I would suggest you search on iFixit "switch Logitech". I noticed there are some fora discussions and also instructions on how to replace the switch (if it comes to that), which parts to use etc.
I'm sorry I can't give you a straight answer.
Good luck!
Eiti
* If you do find a solution, please post it here. I'm sure I (and others) will eventually get to the point where my Ergo will need some work on the switches. Even if you don't want to go through the trouble of taking pictures and writing a complete instruction, just describing your solution as an answer here would be very helpful.
Was dit antwoord nuttig?
Voeg je antwoord toe
Sachin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 31
Altijd: 1,157
